Replacement engine is in and running badly.
Exactly the same problem that i had with the old engine before it died completely.
The video is the car at idle, not touching or doing anything to it. It idles eraticly then revs up a little, going round this cycle again and again.
Video of Idle Issue - Photobucket - Video and Image Hosting
Have unplugged every sensor one by one and it does not go away.
Along with this, there is a lack of performance (power almost fades out around 3000rpm and accelerates slowly) yet the car revs up very quickly when theres no load. The engine was running perfectly in its previous car, so it has to be something i have kept from the old setup. This is, ECU, fuel pump, throttle body, ICV, CTS, TDC sensor and the loom.
I'm almost thinking faulty ECU at this point, or maybe something to do with fuel pump??
What you all think?
Not sure how much more patience i have with this damn car :x
What you all think?
