Idle Control Valve Question/Theory
G
Guest
I have discovered that my ICV is shafted and finding one is proving a little difficult.
I have a theory that if i remove the ICV and block it off, I can use the idle screw on the top of the throttle body (the one that is blocked off) to set the idle speed manually. Is this a sound theory or total bull.
Any thoughts.
jason
No works fine, i used to run the same setup.
But you will have to start the car from cold with your foot on the throttle and hold it there for about a minute before driving off, otherwise you will stall.
Why is it proving difficult to find another ISCV?
I've got a few spare in the garage and i'll bet Mat Brown has got loads!
Sorry. I dont frequent this forum so names and where to get stuff is all new to me.
mat brown or winston usually have loads of spares as do a few others..
post in the wanted sections or ask in technical..
i have a prob when taken over 4k starts to idle well high ! was told it could be build up off shit so cleaned all throttle body etc and still doin it !
is this the idle control valve thing or throttle position sensor ????????
