I stuffed up.
Kett
I bought a load of the shiny bolts from RPD ages ago - thinking I was getting new versions of the rusty looking screw.
They're from the row under the front bumper. Anyone got the correct part number?
james":2uilvlmn said:
http://v6clio.net/manuals/partscliov6part1.pdf
Both ph1 and ph2 bumpers shown
My computer doesn't like that link... :ihatpcs:
I'm sure I ordered the "wrong" parts from a technical picture... hmm...
I could access the manual from my iPad...
...from the Mk I pictures: it looks like I should have ordered part no. 77 03 016 519
I assume it's the same component for the Mk II. :s
Don't forget the clips item 16 on page 85 ;)
Part number 77 03 046 082
Might have to ring RPD myself for a set :approve:
It was approx £1/screw (ooh-er missus!) and £1.20/clip. RPD will take 5-10 days.
Do you recommend attaching 6mm nylon washers (2mm thick) for fitting the Russosport splitter? (Or will it create a nightmarish dirt trap)
I didn't bother using anything, but if your after protecting the bumper paint from the fibreglass chaffing then how about some double sided sponge tape? ( the sort of stuff number plates held on with ) Fit a bit around the inner edge of the splitter and trim flush with the edge prior fitting splitter :approve:
The nylon washers would created a small gap underneath but I think you'd be more concerned with the front painted lip ;)
Yes indeed!
I'm off to Crete in two days and was hoping to leave the Vee at the paintshop during my hols... the screw-up with the wrong screws has scuppered that!
So I now expect to be at Prescott with unpainted lip (it matches the Mk II grills conveniently) - but the finished AY item on show at Kimbolton. ; )
