I'm going to buy the engine for my project and store it untill I need it. It may be a year before I get it in the car as I have the body etc to work on first. Whats the best way to store it to prevent it seizing with non-use? Will it be ok in a spare room under central heating rather than left outside covered in a waterproof tarp?
Is it worth.me have the seller, if possible, to use an engine flush with the old oil, drain the oil oil and replace with new, then to run it till warm to hel lube ut up with fresh clean oil? Or a waste of time given the time it may have to stand unused?
