Help with a Friend's 2001 Clio Extreme
Stu 1986
Hello All, I hope you are well. I've not been on here for a while but that said I no longer own a Renault! :eek: I hope Moggy is having lots of fun with or 19 16V though! :D
Anyway, a very good friend of mine has an issue with his clio. The gauge cluster doesn't work properly. He has no Speedo, Fuel Level, RPM or Trip Computer, but does have most warning lights and stereo display. I'm hoping someone could point me in the right direction. We have noticed three wires going into a plug in the rear of the engine are chaffed and the wire exposed, he says there was some metal rubbing here and he removed it and seen it had done this. Do these wires run to one of the "Brains?" All fuses have been checked.
Also will the wing mirrors off a 2001 Megane fit this Clio does anyone know? One of his was torn off, and there is such a megane in the local Scrappy.
Thanks For your help in advance- Stu! 8)
