help needed on brake set-up
hi,ive stripped my the bendix out of my chamade and now struggling finding new parts, ive been to see many ph2 19 (not 16v) and all of the ones ive seen have the reservoir sat on top of the master cylinder, now I assume these wont fit the 16v models or why would they use the remote set-up? so ive been looking and noticed a lot of newer Renaults use remote reservoir set-ups, so I have 3 questions: 1) has anyone got a brake set-up to sell me? lol
2) does any1 know If I can fit a different type of brake
set-up?
3) will the set-up with the reservoir on top of m/c
fit behind the 16v engine?
im going mad trying to sort this out its the only thing stopping my car going back on the road, any help would be greatly appreciated. thanx
You can improvise a bit, surely?
Get some plastic pipe L pieces (from Homebase/ ebay or wherever) to shove in the rubber bungs in the top of MC, use some bits of hose and mount the reservoir wherever/however you like. That bit's not under any pressure so it'll be fine. It'll do until you find the right bits if youre that bothered.
Ph1 megane diesel uses the remote reservoir so it might be worth checking out a breakers yard for the bits
The non remote reservoir will fit I think, but it'll be tight and be a bitch to get at to check the level/top up
