So I took the phz 1 vee out for a lovely drive today as the weather was good. When I got home I gave her a wash ready to go back in the garage, went to start her and it seemed like the battery had died? The starter motor turned really slow and not enough power to start the car.
I checked the battery voltage which was 12.34 which dropped to 9v as I tried to turn it over. Then went back up to 12+. Using a jump pack the limp / weak starter was the same.
A neighbour gave us a push and it bump started so I could put it back in the garage. After leaving on idle for a while with a decent 13+ volts in the battery I turned it of and tried to start it again. The same limp starter again.
I’m guessing the starter motor is dead. Or possibly the starter relay?
I’ve been searching on here for a couple of hours now and see people recommended a Bosch alternative but can find any part number me or equivalent?
Does anyone have any links to the right part Or upgrade for a phz 1 starter motor?
Thanks in advance.
Thanks in advance.
