Hard water pipes and foam "carriers"
v6Max
Does anyone know the part number(s) for the hardwater piping that runs under the car to/from the radiator? I also need part numbers for the 2 hard foam carriers the pipe work passes through and the rubber hoses connecting the hard pipes to the radiator.
Thanks in advance.
I've found the pipes I think
Item 4. Part number 6020010323 £70.66 GBP
Pipes are a bit of a nightmare to find. Anything on here look useful to you?
Spot on James - thanks very much :-)
Looking at the 1st drawing...
Parts Numers for 1 & 2 would be the radiator pipes
And then the 2nd....
Parts Numbers for 11 & 17 would be the hard foam carriers
