Does anyone know what the best oil is for a HA1 5 speed gearbox.
I am currently using 80w90 and the result is a scratchy change into 3rd gear. If I do a slow change it is as if internal components starts to turn as the gear is being engaged, grating, forcing me to disengage, wait for the cluster or whatever to stop spinning and then doing the change.
If I do a quick gear shift, the problem is not as evident. It is as if I havent given, whatever is turning, the chance to gain momentum. Logic tells me the oil may be too thick causing parts that should be turning independently to turn together????????
Any advice?
Any advice?
