5 GT Turbo Guide to 5 Gt Turbo instrument, speedo and tacho board contacts
Fordy
Little tip
If you have poor connectors on the speedo and tacho boards
You need
Flux
Wick
Good solder i use 63/37 leaded
Flood the wick with solder
Then gentle press the wick over the flux/board connector
The flux cleans and the wick leaves a very thin tin on them for making the contacts good again.
Best and only way these should be repaired. Apply some deoxit or any other contact protective coating for longevity
