5 GT Turbo Gearbox shimming
Chris74#
Guys, does anyone know where I can get a setting shim for a JB3 gearbox? I had to use a different case when restoring and need to re-shim it! Apparently!! Thanks
Isn’t your gearbox builder doing that..? Or are you building it yourself..??
Gearboxes are always an unknown for me. 🤷🏼‍♂️
Yeah, I stripped and rebuilt it, but I messed up and decided that cleaning an aluminium case in caustic was a good idea! I then couldn’t get the caustic staining off so sent it to vapour blast. When I went to put it back together the bearing holes and oil seal holes had all grown 🫤🤔 I had to switch the case, out! I got that case vapour blasted, put it back together tested it before fully tightening the two case together and it works fine, as soon as I torque the cases up, I can’t get 4th gear at all!
