|sAs|
Hi
My car has done about 175000 miles and it feels like some bushes are quite worn.
I figure I'm going to buy these:
http://www.mespiecesauto.com/70-kit-barre-stabilisatrice-r21-turbo.html (obvisouly I need to measure first, do I need to remove the bush that's on or can I measure right behind it?)
and these:
http://www.mespiecesauto.com/94-tri...0758441-7701161724-7701161726-7701161727.html
http://www.mespiecesauto.com/95-tri...0758441-7701161724-7701161726-7701161727.html
I have cast wishbones on it now, will it be ok with pressed?
Also, I don't seem to be able to find new TRE's are they Renault only or simply unavailable?
I'm also considering getting the GAZ coilover/lowering kit for quadra. How is the ride with them, is it much harder than standard shocks/springs? I want the rear lowered about an inch, which I've read they'll do. I also don't want it to be hard lika a go-cart, maybe I'm better off with the lowering kit at the rear and new shocks up front?
After all this is done I will have tracking checked/fixed.
Is there anything else I should be getting to have it handle like new?
and these:
