gents, i have tried to fit the gearbox to the engine on the car, twice, and failed. As i push the splined gearbox output shaft into the engine it gets to a point were it wont go any further, as if the output shaft is too big for the spigot bearing.
I've aligned the clutch both times, quite accuratley, once by eye with a dowel and once with the proper alignment tool, neither helped.
I got a new spigot bearing from a helpful contact in hereford (wormbridge) to go in my new crank from mecaparts. it looked the same size as the one i took out my old crank but i didnt measure it.
This has destroyed my morale in finishing this 7 year project...
fully embarassed and a little heart broken
if anyone can help you guys can.
