In the process of changing the timing belt on a 19 16v with an F7P engine. Have not removed the old belt yet.
I have removed all the covers so I have access to the belt. Went to find the crank shaft locking hole and found that it is very difficult to access. I don’t think I can get to it without removing the radiator.
My question is how important is it to actually lock the crankshaft given that I have both marking on the crankshaft pulley and the new timing belt.
The replacement belt has markings for both camshafts and the crankshaft.
If I just replace the belt and make sure all the markings line up, isn’t that enough?
