F.P.C Clio 16v Tuning Guide
  • Thread starter Thread starter Guest
  • Start date Start date
  • Tags Tags
    clio
G
Guest
dint realise how long it was but here goes !
BASICS -
first off we all know bout arches and power steering pumps and steering column joint ! watch out for these !
it is essential if you are serious about performance to uprate suspension and brakes ! and also says if the car has been lowered (on torsion bar) recomends gettin brake bias adjusted so back end wont lock up !
cambelts - 60000 service - 3000
STEP ONE - INDUCTION
any will do ! i recomend pipercross lookin at 3-4bhp gain
STEP TWO - EXHAUST
there are many good options out there! but advice is to (if you can) do it all at once - exhaust, de-cat, manifold ! lookin at 12bhp+
STEP THREE - FUELING
you should notice some gains from using super unleaded ! but FSE power boost valve is recomended in line between fuel tank and throttle body !
coupled together with induction and exhaust should be some good gains !
STEP FOUR - HEAD, CAMS & CHIPPING
top clio tuners will start by removing some offeding metal from inside the head tracts to open out the ports and smooth the route through the head for the intake and exhaust gases. A decent tuner will remove the valves and grind multi angle seats into the head and then lap the valves to match for a perfect seal. ANYONE WHO DOESNT REMOVE VALVES AINT WORTH IT !
once the head is done its time for cams and chips (mag recomends k-tec)lookin at 170-193bhp but if more than stage one might be makin a bit of a track beast that will idle more lumpy !
STEP FIVE - FORCED INDUCTION
when you consider throttle bodies will give you around 15-20bhp for about £3000 why not go turbo !
for around £4000 you get instant 200bhp and thats just a low boost conversion ! youll need to fit a thicker head gasket to reduce the compression ratio ! if you want the high boost conversion your lookin at 240bhp for an extra £1500 for the extra cash youll get lower compression forged pistons and rods and a paddle clutch to handle the 14-17psi of boost !
all from December 2007 issue
What a shit guide.
Did the OP make that or was it copied from a magazine, if you made it robo i apologise for the bluntness, but it makes me cringe reading it.
Laine_16v":94xytlsn said:
What a sh*t guide.
Was going to say that is shite. 15-20bhp from TB's? Poorly set up maybe........
12bhp from an exhaust system............not on average. I know de-cats are good, but generally systems net 2bhp at best. Manifolds again are hit and miss, and it depends if heads are port matched.
That guide does seem very thrown together? How about some info on what RPM's and Lb/ft standard internals can take, how much power standard injection can handle.
Seems to be miles behind VW/Vauxhall/Ford in terms of options and write ups. I don't think the current French Motor Mags do the cars/engines justice really. A very generalised Revs of yesteryear write up. Shame that.
Again not a dig at Robo. At least you were thinking of the site! 8)
its all good, i couldnt agree more ! im not the most mechanically minded person but even i think that is poor at best !
It was wriiten buy an ex Rev's/fastcar free lance writter lol
Gutted theres a pic of my car in that guide lol
haha i noticed that ! you still got the BBS rims off the 'illiams ???? got Nov 07 issue with it in and 2 phat 5's
does seem poor/optomistic...
was it specifically a 1.8 16v guide? why is the no mention of an F7R BE ;)
