Engine parts
Spike
Hello to all,
As you may or may not know i broke a couple of these a few years ago and have a few engine parts kicking around that are all in good fettle. Some oddments but mainly engine block parts including Blocks crank and pulley parts. All this needs to go!
This is in addition to my other parts posts.
Let me know what you want as there is too much to list.
Hi Spike,
Do you have camshafts?
Dephasers?
Oil pump?
Inlet plenum?
Any drive shafts and/or gear shifter cables left?
SPIKE":1vjz3ffr said:
Hello to all,
Passenger side driveshaft complete?
Replaced the outer CV on mine last year, but had to use a Laguna outer CV, which now means I need to get an ABS ring made to match the slightly smaller diameter. I'd think about just buying a whole Vee shaft for simplicity if you had one.
Adrian, i sent you a lengthy reply and did not receive a response.
For the sake of completeness my response said that i did have the parts required but i do not post or discuss prices until i know exactly what parts are actually required.
The parts i have in stock are all rare to the extreme and have been collected bought over many years, I will say my prices are high but the quality is top notch, you will not find better parts or a better description.
I will pm photos to WhatsApp or messenger but will not post on the forum.
I hope you understand. Spike 07889 153352
Did you see this [mention=2520,#000000]SPIKE[/mention] ?
Hi Spike, I have received it. I know these a super rare, I was thinking about it and busy getting my Vee back on the road and forgot to reply. Will do shortly on PM.
