engine light on after coil fail
Diesel99
had a coil go at the weekend and the "engine" light on the dash came on (flashing first then constant) ......changed coil but light still on ...... will it go off/reset if I disconnect battery? is first question please.
yes james I see that in the "how to change a coil" advice . ive done about 25 today and its still on so ill wait and see cheers .
next question is if/when I disconnect the battery ,ill need to re set radio code there are no instructions on this in the book . There is a no 8 in the code for mine but only up to six on the radio.......basically how do I reset radio code if I may ask ............................cheers
Found this.......
thunderstarter wrote:
Will wrote:
Sorry to hijack your thread, but rather than start another thread I thought I would ask here as it seems relevant. I have the original code, as stuck in my owner’s manual but when I try to select any numbers all it does is beep and leave the screen blank like this:
Rather than any of the digits I have attempted to enter displaying on it.
Has anyone else experienced this problem and is there a way of rectifying it?
Thanks,
- Will
How are you entering the digits? Via the head unit? If so, this is wrong you need to scroll through the numbers using the thumb wheel on the steering column stalk and then select with the rear button on the stalk, which then moves onto the next digit and so on.
#11 Postby Missing Link » on 17/11/11 19:10
Once it's all in, a long press on the rear button will enter it.......
FYI .............. light didn't go out after dis connecting and then reconnecting battery .......BUT it did go out on its own after 40 odd mile (as per James s post ) ...............cheers
