Chunk
The door handles on the Ph1 cab don't feel as springy as they should be.
When you open the door, the handle doesn't quite return to a normal position and sticks open a bit. Feels like it doesn't have enough spring to return properly.
Anyone else had this? Small thing but it annoys me. Slowly fixing all the little issues to make this car great once again.
I tried to remove the door handle to have a closer look but couldn't get the handle off after i'd removed the securing screw, i couldn't get the handle off the metal rod.
