Damper rebuilding?
I recall reading that someone had sent their dampers to Koni for a rebuild, is that correct?
What is the rough cost per damper / is it cheaper to get BC Racing replacements? Indeed are they any goos, or a load of shiny shite?
Mine has developed a knock from the OSR and Everything that has been checked is tight / not worn / replaced apart from dampers.
There is a slight oil weep on the damper so I believe it's on its way out.
Just wondering what the best course of action is from hereonin....
