cup air inlet?
Status
Not open for further replies.
r5cup
hello. i search for the cup piece for the frontbumper. left and right. orginals.
thanks for help.
IMG_20150504_141833.webp The best of luck..... Most have been smashed up.... Have only ever seen 2 sets , and one of those were broken......
Most got smashed. We have a couple of sets on cars here, but we ended up making a couple in aluminium sheet for the racers in the Super coupe cup.
They can be made from aluminium sheet quite simply. Cut the top and bottom profile with some tabs along the side which bend over, and then the rivet the sides on. it will take you a few hours with some tin snips.
Or you could produce a pattern and have a batch lasercut.....
Aluminium ones look almost identical when tucked under behind the bumper.
Status
