Taking it apart...
Not much wear to the chain tensioner...
Standard cam sprocket...
It was at this point I realised the sump was still full of oil....
The C1J fairy leaving nice presents for me....
So the owner of the engine and I decided to reuse the pistons, but change the liners and rings. Reason being is that a guy local to us was selling a new set of kolbenschmidt liners and pistons with rings for a volvo 340, for a very good price. So use the new rings and liners and jobs a good'un. The crank is in good shape, the oil pump is shot.
How long do you leave it in there mate? I had a bad experience with the caustic soda and my gearbox casing! Although I now know not to put ally into caustic soda!!
I left it in for a day, then took it out and jet washed it. Then using fresh hot water and a new bottle of caustic soda I've dunked it again. It's on day 3 now. You must remove the engine number, else it gets eaten away in a couple of hours. Use the thickest feeler gauge, slide it under the engine number plate so it is touches the rivet, then use a small hammer to knock the steel feeler gauge through the soft aluminium rivet. Repeat both sides, keep the rivet heads and RTV them back on later.
So I got the jetwash working and sprayed the block clean with water.
I then took it inside and dried it out.
Then back outside for adhesion promoter and first coat of paint.
I like to clean up the bolt holes afterwards with a tap and I'll clean up the mating surfaces with a razor blade, sandpaper and scotchbrite.
I have access to sandblaster for zero cost. If you wanted to be picky I'd say it also leaves the surface ripe for paint, as the bare aluminium loves to oxidise in moist conditions.
