Sunday 28th November 2021 - A fabulously calm sunny winters day, after the storms of yesterday!! So with that, at I was all fed & watered, and WELL wrapped up from the 2C Temperature
at 08:47 made a start!
First was the new Starter motor, exhaust manifold, exhaust manifold to Catalyst coupling and then subframe.
Next up was a new pair of OE SNR Driveshafts:
With the driveshafts fitted, I could then get the gearbox refilled with oil. Next was the new lower wishbones before I would fit the new front radiator support (Very clever how many things interlock on this car)
Everything then Torqued up to OE Specs.
Next was to switch over the fan & water bottle from the old Radiator (Which was looking well past its best!!) to the new:
Quick progress check photo:
Then re-fitted the Radiator and Air-conditioning Evaporator:
After a super successful ~6 hours, I called it a day at 15:08:
Not too far to go now, reckon if I can be lucky to get another clear dry day, I’ll have this puppy back together!
Thanks for dropping into the Big-Steve dome!
