Hi all , i have a problem with the battery draning overnight when the alarm is activated , but if the car is left unlocked it is ok .The battery is new . Any thoughts ? sorry if this has been asked before . Regards marc
Hi Danny , thanks for the reply , i have a c-tek charger . the problem is that from full charge in the battery it will go flat overnight if the car is locked , but if i leave the car unlocked the battery is fine the next morning . regards marc
For putting the battery on trickle charge is there a connection in the car I can access rather than having to remove the front boot liner to get to the battery? Or do I have to make up some fly leads?
Ctek offer a cigarette connector for there chargers BUT it didn't work on my vee!!!!!!! Seemed to power up the top dash ( radio display ) and ended up draining the battery :rollseyes:
Hi Chris , can you let me know how to lock the car and deactivate the alarm . i have tried locking the car via the passenger side with the key but it only seems to lock that door and not the drivers side . Think you are on the right track though as the alarm does chirp slightly at random . As you can see i am a newbie numpty . Regards marc
Hi Sean , it is all locked up minus the alarm , so time will tell hey . wish i knew how to lock the car without the alarm sunday as i took nipper to the little thief for breakfast . parked her as close as poss but had to crook me neck to see her ( still bloody hurting today )
Cheers sean , just tried starting the car today without the alarm activated overnight and had no probs starting at all . Can you tell me where the alarm is situated so i can use my trusty general hitting tool on it . Thanks again . Regards marc
If it's anything like the standard alarms of that era (The Phase 1 had a different system) then it will be in two parts, The " Brain" will be located under the passenger air bag.
The Siren will be located under the plastic cowl underneath the wiper arms at the passengers side, Now the usual problem with Clio alarms was that this area had a drain hole that blocked up and water soaked into the siren and caused all sorts of problems.
If i was you i'd see if this could be disconnected and then tested again, The alarm functions will all still work but there will be no noise when triggered......... All that unit is a siren and the back up battery that it needed to qualify as a Cat 2-1 alarm.
It is feed a constant live to top up this battery, But if it starts going green with moisture then it can drag the main vehicle battery down with it.
If you turn the key in the ignition 3 times in succession (not so the engine starts though) shut your door, when you then lock it you should hear the alarm beep 3 or 4 times then the alarm is de activated, thats how i do it.
