According to the workshop manual, the vee has follow me home headlights, ie they stay on for a period of time after turning the ignition off to let you see what your doing.
AUTOMATIC VEHICLE LIGHTS ("Follow me home" function)
These vehicles are fitted with dipped headlights that come on automatically (when the engine is switched off). This
function operates for 30-second periods and only when the ignition is switched off.
Activation
It is switched on with the lighting stalk:
switch off the ignition,
turn on the main beam headlights twice using the stalk,
the instrument panel beeps,
the lights will be power for 30 seconds,
another 30 seconds are added each time the main beam headlights are turned on with the stalk.
