Anybody want a tracker.....
Missing Link
......... Opened up mine due to a bad battery draw and found 3 and two alarm systems........
I'm pleased to see this lot ripped out. :approve: I recall questioning previous adverts regarding trackers/alarms on #100.
I knew something was not right as the dash top wouldn't sit right...... Christ you couldn't fit anymore stuff under there it was jammed packed and all still live..........
Does anybody know what security system came with it at new ? I have a Clio 172 with a Factory/Cobra system with blipper key.
Would it have been the same ? All i have now is a standard non blip key
The Clifford on it got binned, before it lets go............. And it would have.......... :rofl:
Cheers James., You wouldn't have apart number for original plip in the PH1 hand book (Page 1.02)
I have one of these alarms in stock and the plan is to fit it but need to find out if i can purchase 2 blips and get them programed to the car now that the original two are missing.
Popped into a dealer today to ask the question and received a blank stare, Granted the parts man only looked 17 but the older guy's were clueless about it too..........
Also i have a alarm spec sheet i can send to you for adding alarms which show you the pick up points, Not sure how to upload it to the knowledge base.
The electrical side in there is a bit sparse, so might be a good idea to add a bit to it.
