Another Vee Shoot!
15mm spacers rear... Soon to be 10mm on front once the H&RS have been modified...note to all, 10mm H&R spacers are made wrong and will need modding
Sophys kept back my faves for the time being ;)
I quite like the wide rear, standard front stance!! 8)
Take it your coilovers aren't much lower than standard height?
at their highest, they are 10mm lower than standard. mine are currently wound all the way up to this setting, but im running 35's on the trye profiles so although the car sits lower, the arch gap has increased slightly. To compensate for this once I fit the front spacers. i will bring the KW's down 5mm all round. :approve:
that should mean that im 15mm lower than standard on the suspension plus an extra 5mm lower from the tyres
I should have the same set up on a couple of weeks when I pull my finger out and fit my KW's.........already have 35's fitted to the Cromo's but a little worried about how the clearance will be on the rear arches.
Although a couple of the Guys on here seem to run Cromo's and KW's no problem ????
RUSSO":1iypeb3m said:
Looch, front splitter - could you give me some details - very nice.
Hoogi, speak to me ;)
Or pop round and you can make your own :rofl:
Have a look hereLINK
Hey Russo,
Forgot you were a talented Man.............so another one of your Masterpieces.
I actually thought it was Carbon Fibre at first glance.
And yes, once I'm up and running I'll drop in to meet up :approve:
Hey Russo,
It nearly was ;)
The flange face on the front hubs sits out more than 10mm so the hubcentric spacer doesn't fit against the hub face.
Ali":154sy7we said:
Is this the same with all spacers? Or just with the above?
What's the remedy?
Just 10mm if hubcentric.
Remedies:
No spacer, 5mm flat hubcentric, 15mm or 10mm and get the grinder out and trim 5mm off the face ;)
