Lankan":1wxdw448 said:Jon, that would be a serious amount of cash, which I am sure you will be hard pushed to recover, except in enjoyment and the status of having a one-off! Hats off to you though for being different. :salut:taipan":1wxdw448 said:It's a necessary development brought forward unfortunately. The standard ECU just can't keep up with all the extra air introduced.
To be honest I would rather have split up the ITB and ECU sides anyhow as together they'd be a fairly formidable outlay!!
Still very much at research stage though. Want to get it right first time. But yes my aim is still to have it ready in time for the Spring road trip Nas and I have planned.
Look forward to seeing the finished article............ :approve:
Ben, did you end up with a custom built exhaust manifold? For me the exhaust manifold is the only thing that I would want to change. Also heard that you have done wonders to the front end of your Vee. Would be interested in talking to you about the details, and whether you have that as an offering.Mulgari":1wxdw448 said:The question we ask everyone that comes into us, is "what do you want to achieve" the OEM ECU does have scope to be adapted but to a degree. If you want to go ITB's then after market may be required, but if you are just adding exhaust manifold, cat and maybe plenum spacer then the ECU is more than capable of being mapped to accommodate and deliver the additional performance from the mods. Sometimes when tuning stock ECU's its not necessarily the ECU that becomes the problem, more the data read range from the stock sensors ie MAP, MAF etc.
I did eventually finish the manifolds!!! what a labour of love, motor feels great since the build. I haven't had chance to run on the Dyno yet but the initial feeling is mega!! We are defiantly going to run a tweak on the map as well. I am hoping for 290 - 300 which will suit me down the ground!! There has been a slight downside to the new manifolds, in that the engine bay temps have increased somewhat. The plan is to have the manifolds back off and send them off to have them ceramic coated which will do wonders. Plus working on a cooling system for the engine bay as the heat is the enemy!!!
