Advice needed : Really dirty ID3!
andybond
DataHoover
Staff member
For one reason or another my wifes ID3 is filthy.
Its a white car if that makes any difference?
I have been looking at TFR and high alkaline contactless cleaners. Any advice out there? I want a product that will remove 90% of the detritus that is on the car. It doesn't need to be mint
I use Carbon Collective foam, iron out and prewash - I give it a lashing of prewash for the body and iron out for the wheels funnily enough, leave it to stand for a few minutes (without letting it dry) before blasting away with the washer thing. Then do the same again but followed by a soapy titwank layer of snow foam. CC foam is very clingy and after 5 to 10mins makes quite a difference, when you power wash it will be quite easy to cut through the crap and make it look decent.
It'll benefit from a clay bar rub down etc making the above process much easier.
Or, go to a car wash that has a jet wash bay, lather the bitch in the prewash, jet blast it off, repeat if you have time.
