-31 actuator
Hi, just considering buying a -31 actuator, i have ebay item 130244032189 in mind, will this fit ok? and will i get any benefits from it or is it a waste of time?
my car is a phase 2, only mods are pace intercoolers and straight threw stainless exhaust, induction kit dump valve thats about it at the minute. any help much appreciated.
thanks
Short answer is no. You will need to find the rod lenth that goes to turnbuckle and work from there.
Idea behind the actuator is it has a stronger spring so can prevent spikes in boost when working at higher boost.
next step , take old actuator off , put new one on ..
For the price that it is going for at the mo , worth buying , and seeing if the rod screws into the existing turnbuckle ...
IIRC Forge will do the rods , you just need to measure up the lengths of the old one that is fitted , the new length of the one to be fitted and that will then give you rod --> turnbuckle length ..
