Having to break due to serious rust issues. Most parts available. PM for more details.
Engine Spec - very low mileage since build. Photographic build file and receipts.
Kent F528 cam 1600-6500. NGK VX spark plugs. MD80S stage 4 Hybrid Turbo Dynamics turbo running 22psi max boost which has since been rebuilt with larger compressor wheel, compressor and turbine housing with opened up throats in the turbo to increase A/R. In car boost controller and boost gauge. Prima Racing Re-Programmed ECU with ‘hot shoe’ to allow chip replacement / mapping when rolling roaded. Scorpion single tail pipe stainless exhaust system with custom centre box removal. Modified MD97 Prima Racing Head with enlarged/matched ports to inlet/exhaust manifolds. Custom fabricated stainless steel tubular manifold, new pistons balanced with liners (individually and as set with (new) rings and rods). 360bhp max flow K&N cone filter. Milled out throttle body to 60mm to allow increased air flow. Samco silicone boost and some coolant hoses. Large front mount intercooler. Prima twin piston atmospheric ‘dump’ valve. Adjustable Cosworth fuel pressure regulator with gauge. Silkolene Pro R 15W-50 racing oil as specified by Turbo Dynamics for their hybrid turbo. Spal cooling fans. K&N breather.
Offers over £750
Super Turismo style wheels (not sure which make. Mint in gloss black - 7.5 x 17's. 2 1/2 worn 205/40 tyres-£250
Front Strut Brace. -£75
Cobra Recliners good condition with suitable subframes - £120
Very good bonnet, has cosworth vents nicely fitted , one of the vents needs painting. £40.
Nose cone panel - mint -£50
Very good front bumper - nicely finished with additional mesh vents and large driving lights finished - one of the lights needs changing though - £100
OS front wing mint -£30
ns front wing mint except for 50p size mark £20
Both front doors mint -£50 each
n/s back door mint - £50
o/s back door little bit of rust in usual place but easy repair £15
Both wing mirrors mint -£25 each
Boot Lid mint -£25
Rear bumper mint - Again not much call, £40
Very nice 3" stainless exhaust, 1 box system £125
Large front mount intercooler £100
Back lights - £10 each
Front indicators £50 each
Virtually new set of standard oil cooler pipes - £50
Calipers £25 each
Front and rear screens -£50 each
driveshafts -£25 each
Sill protectors - good not mint £25 a side
Also lots trim and switches or anything else not listed - mail me with what you want
