Wanted 21 aftermarket parts
Haz
does anyone have :
a pair of ali replacement intercoolers
Blue silicone boost hoses
Front mount and hoses
Full Quadra stainless exhaust
Air filter and intake pipe
Oil cooler kit
Even the pace ones? Unfortunately none of the aftermarket bits fit properly on James Quadra so just seeing what else is available as may be a cheaper option than me having to rework what's there, sourcing/supplying missing bits and making brackets etc.
The current cooler wants half the pipework changing and just dangles in front of the rad.
The downpipe wants the flange cutting off and rotating.
The air filter pipe is smaller diameter and shaped to fit oe turbo, as is the air filter neck.
Oil cooler doesn't mount where it should be due to turbo.
Turbo is missing the oil feed pipe, a water union, has an extra bracket for the actuator instead of rotating the housing? and no water pipes either.
It can either all go back to oe, or be resolved. Just working out which would be more cost effective for him.
Yeah I could get the bits and make it work, same for all the other alterations which is fine when it's your own car but its just another expense for something that isn't essential to get it back on the road. The more direct fit bits the better at this stage.
