Finding a quiet place to practice starts would be the most sensible start point. It's always going to be a balancing act.
Makes me think back to hillclimbing in the mid-late 90's
There were 2 guys both with 2 litre Caterhams (red tops) one had all the bells and whistles tech wise at the time and a Swindon Engines Motor which would have been around 275bhp no problem
The other car was very well made, but home made and had no tech and probably about 20hp less.
The first guy used his tech to the limit all the time, the second had some of the best throttle control I had ever seen and as a consequence was always a tenth in front wet or dry. I am not trying to dismiss tech here, far from it, but you can never underestimate good driving. I was always a bit of a hammer thrower and was lucky enough to have driven a couple of single seaters, but did not have a deft enough touch for them.
I count myself lucky that I started in Hillclimbing, then added sprints and finally went racing. I was always quickest on a clear track, a lot of racers I know get a bit lost on their own, because they have always only raced. It's hard to explain, but if you are in the lead you just need to stay there to win (easy to say I know) when sprinting and hillclimbing you are always trying to go faster than before.
I would think you have probably heard this tip before, in Qually if there is someone who is just a bit faster than you, If you find them (usually Qually ends up looking like the actual race) if you have caught up to them, let them get away, then try your damnedest to catch them, if you can you have just outqualified them without actually passing them, I used that one regularly.
The other one is that if in a race you are see-sawing to the guy in front, try to work out where he is quicker and work on that, it is usually a mistake to try to capitalize on the places where you are quicker, as you are probably nearer the limit, trying to find time in these places usually results in an off....
I'm still jealous by the way..............
