19 1992 19 16v Not Starting After Rebuild
CRAIGUSF1
Hi,
Okay, so.. I've been restoring my car over then past 3-4 years, its been stripped and rebuilt using about 90% of new parts. The engine has been out, stripped, head skim, repainted, cleaned and assembled with new bolt on parts such as starter, alternator, belts, water pump etc... All the internals are the same. Injectors had been sent away to be refurbed too.
Now its all back together it won't start. It turns over but I don't think I'm getting a spark and I can't hear the fuel pump kicking in. I can bridge the fuel pump relay so its on, so I know the actual fuel pump is working.
When I match the two marks on the cam cover with the marks on the cams, piston 1 is TDC. Is there a mark on the crank that needs lining up with these? I'm not sure.
I really am clutching at straws, I don't know if I've left a plug off or whether I've not put the engine together properly. I don't know.
Hopefully when I find what I'm missing, its something obvious and stupid.
Please help!
Cheers
Think I'm going to take the aftermarket immobiliser out. After reading up, so many people have had problems with these over time so I think the best bet is to completely remove it.
Any helpful pointers I need to know about? Is it as simple as just taking it out?
Think I've managed to take out the spaghetti of wiring, there were a few wires that needed reattaching. Mainly the ignition wires.
There are a few plugs that aren't connected to anything and I have no idea where they go...DSC_1102.webp DSC_1103.webp
I would only worry about the wires that were physically plugged into the immobiliser for now. You should probably have ignition live, +12v battery and an earth,these can just be cut at the source. Now depending on what circuits are immobilised you will probably find,(when you trace the wiring back), that the original wires on the car have been cut,so one side of the cut wire will bean input to the immobiliser and the other side of the cut wire will be the output from the immobiliser.
Hope you can understand this its a bit hard to put into words!
As long as the wires that have been cut are all of different colours then just cut out the immobiliser and re join the wires job done!
Good luck
Okay, so I took out the immobiliser. Waited for a spanking new optima battery to turn up.
Connected it, turned the key and nothing. Lights came up on the dash, that's it.
No fuel pump sound, no cranking. Clock works though!
Please help. Any ideas?
Yeah, the fuel pump was working when I bypassed the fuel pump relay before I removed the immobiliser.
Think I need an auto electrician. It has to be the wiring. Everything else on the car is brand new.
