#148 2002 Mars Red on PH, 15,800 miles
Lankan
[v6plaque]148[/v6plaque] is a Phase 1 with a Phase 2 front end, side pods and rear lights - the excerpt below from the advert explains the reason (£22,990): LINK
"Sadly placed on VCAR register in 2006 due to light panel damage hence bargain price. Genuine Renault panels used, Repaired with no expense spared, Inspections are welcome..."
Was a cat C write off in 2006. I would take "light panel damage" with an appropriate pinch of salt.
Very expensive for a cat c bitsa, in 2006 all genuine Ph1 parts were available so should have been rebuilt as a Ph1 not ph2. As previously said wheels look all wrong. Would possibly be worth this if put back to oem but will always suffer a big cat c discount, if it had been panel damage only it would have been cat d, cat c normally means structural damage that can be repaired but is beyond economical for the insurer. The value of vees in 2006 would say more than a minor panel scuffer :) Duncan will give a good idea of value but my guess is that this is over £5k more than it’s worth!
