who loves head... ?
G
Guest
Corny title..
Am i right in thinking the valver head and the 19 head is the same..
Im sure someone said there is a difference, but i cant remember..
thankyou...
Thermostat housing is different, the sensors screw directly into the head on the 19.
Mat.
thank god just bought on including cams cam cover inlet fanimould and tb for 20 quid :lol:
so i can fit a clio head to a renault 19 bottem end...correct ?
dont i have to use the clio`s manifold aswell....
I havent tried this before but I would almost definitly say yes you can. I'm sure you can use the thermostat housing off a clio for your coolant temp sensor & interior guage. Not sure if those 19's run an electronic water pump? If not, just leave that sensor unplugged. Got a picture of a 19 head?
yeh they got the secondry water pump......
the only other thing i can do is use the whole clio lump i got..and sort the mounts out...
I'm using a 19 head with a valver thermostat housing on mine. Left the sensors in the head to stop it leaking but i don't use them.
