Which Airbox - ITG/Pipercross?
10
Hi all,
I'm in the market for some sort of airbox for the V6, for the noise benefits. I messaged Scott and he mentioned that he has fitted some ITG airboxes to V6's before, although he mentioned they are no longer available? I got in touch with them directly and they said they have no experience of one of their airboxes going on a V6.
I'm hoping someone on here has one of these?
If all else fails I'll go down the pipercross route.
Thanks,
Oli
I fitted bmc cda induction kit, if the wife is viewing, it was to cure heat soak causing fuel evaporation, sounds fabulous, quite loud with passenger window wound down. I did insulate the feed pipe as well and have never since experienced any heat soak on induction side.
I seem to recall the pipercross was plug and go, whereas the BMC CDA needed some additional silicone hoses. There’s a fitting guide on here somewhere for the later. Quality item.
