Doers anyone know where the fuel pump fuse is on a ph 2, yes, i have searched the knowledge base, no luck, i know the relay is in the front fusebox, but as for the fuse? is the injection system fused as one whole unit? (bit stupid i know) any assistance please.
thanks james but checked those, tried pulling the fuses but pump still runs, if you pull the 30 amp one with engine running it stops the motor but fuel pump does run on, then puts management light on. pain in the ass to keep resetting so thought i would ask on here, and save my sanity.
Ha! after a lot of messing around have finally found the fuel pump fuse. its the 30 amp small fuse thats under the bonnet on pass (near) side, got a little confused because when you pull the fuse the engine will run on until all the fuel is used from the line, this takes about 30 secs. and just to confirm it is the yellow relay as allready mentioned, this is a std relay rated at 40 amps. thanks to all.
