Where does this tube go?
CoolAsLife
After finishing the rebuild of my v6, I've found this little tube laying in a box - and for the life of me I cant see where it goes or what it does.
Its from the rear tailgate opening mechanism. I initially thought it was from the washer tube assembly, but it's not.
Any ideas?
Oldskoolbaby":1o5zt8i1 said:
Is it the tube that attatches to the bottom of your under bonnet luggage tray?
Did 230's come with that appendage? If so, I must be missing one.
Mine never had one but I'm sure I've seen them on other cars.
yes there is a rubber tube fits on the bottom of the plastic boot under the bonnet
I know because mine got lost but sounds like everyone else lost they'res too!
I guess that means a lower score if i enter a concours event in the future lol
I didnt have one on my old v6, so was a little suprised to see it on my mars as id not seen one before.
I guess its to drain water from the storage compartment and aid its run off through to the floor.
Have you had your tale gate lock out, there is a tub atattched to the boot lock/central locking in the tail gate
I finally got round to fitting this tube back in place - was quite simple in the end. As mentioned above, this is a drainage tube for the tailgate handle.
This is the tube in question
It attaches top left - which would be bottom left with the tailgate closed.
It then goes to a hole in the bottom of the tailgate.
I fed it in from the bottom of the tailgate with the black plastic outlet on the outside.
I assume without this tube, any water getting into the handle would drain inside the tailgate.
