DaveL485
Staff member
Ten M14 x 1.5 studs and nuts for the front of a R21 Turbo. Unused as they don't fit the wheels I want to use (I need special slimline bolts for the BK604's).
These are 20mm longer allowing for spacers and bigger rims/different offsets. Can be cut down to length if so desired. Nuts are captive ends (you cant see the stud through the back of the nut)
Pictured here:
Cost ?40 the set, i'll let em go for ?30 delivered (postage is about a fiver).
Pictured here:
