ray":s42lduyo said:im thinking a golf r32 turn the vee into a 4 wheel moster plenty of vw tunners
k1ano":33qyakqc said:Am not sure 4wd in a vee would work anyway due to the short wheelbase and low weight front end, I could easily see a big power cosworth turbo engine mounted low in the back though
T1RBO":2kmhvuyf said:Not sure that modifying a vee is a sensible idea![]()
Oldskoolbaby":6w4lsh4m said:That engine would be a pain in the ass to fit. Its never been fitted to a transverse gearbox so that problem will have to be sold. If the UN1 'box was to be used, the floor pan of the vee would need completly redesigning. Also its not the same engine as the new skyline. A fair few people seem to think it is but its not. Im pretty sure eery nut and bolt was newly designed on that particular car.![]()
TRW1":mwaku34h said:T1RBO":mwaku34h said:Not sure that modifying a vee is a sensible idea![]()
A small lightweight turbo engine in the back is the obvious thought and heat issues can be resolved but you need to make sacrifices and drill a few holes somewhere.....
There's a long-running project on Cliosport putting such an engine in the back of a standard clio....
