G
Guest
Firstly this is not clio related :lol:
my 306 td is smoking alot when going flat out..
basically wen the turbo comes on boost it leaves big clouds behind it (its not black) but its not using much water but using quite a bit of oil.
Am i right in thinking then it is burning oil through the turbo :?:
Is this really bad for it?
Last night i was cruising about 95 on (my private) M25 and it was smoking quite badly but running fine and temp was normal so should i actually worry about it or just keep topped up with oil and expected it cos it is after all an old tractor engine :roll:
