All I know is the trophy engine is an LXA 700 Type V6PR with twin plenhams and they put out 285bhp. Gearbox is likely to be a Sadev 6-speed sequential with LSD I would guess?
280 -> 285bp, Sadev Sequential, different heads, different inlet and exhaust cam profiles, no cam timing switching, different fuel rail, different injectors, different flywheel, Magneti Marelli management. The block looks the same though!
I've seen that very picture on RaceCarsDirect and given the glacial rate of progress of mine I was tempted...
