Tire pressure?
1.4 bar front and 2.1bar rear according to handbook although I've read 1.6bar somewhere for the front as well....
If you put in Tyre Pressure it comes up.
Also go into Google and put in 1.4 bar to psi amd you will get the correct answer.
Front 20.3 psig
Rear 30.5 psig
My door plate and also hand book say different for fronts e.g. -
Front 23psi
Rear 30psi
So which is correct?
Hi James,
Its the plate on the door that came with the car that has this info.
i'm thinking cos the car is in Hong Kong that different tyre pressures were listed e.g. hotter / more humidity here?
the car is running Yokohamas
