11 Turbo Stiff Turbo after sitting
jack11electronic
Hi All,
Finally got my 11 turbo's bits back on & running again after 7 years of sitting.
The turbo is now stiff when I move it by hand,and doesn't budge at idle. Maybe just a matter of running it (at idle) for longer
Any tips on this would be great!
Cars is standard setup.
Thanks
Jack.
It sounds like the oil has gell/ gumbed up around the shaft, I would change the oil & run up until very hot then recheck if it is free change the oil & filter.
If it is still stiff you may have to get it rebuilt and the oil feed cleared then change the oil again.
Our lord and savior has spoken.
The t2's pretty much stop at idle. I would just change the oil and run it, assuming it was ok beforehand it will probably sort itself out with a bit of use.
