L1011
Failed CV joint on the wife's shed (not bad for 170k).
Removed the complete shaft and outer boot and attempted to tap off the joint. More and more force was used until it became obvious it just wasn't coming off. I assumed I wasn't transferring enough force into the actual inner locating race. So I quickly cut through the cage and let about half of the ball bearings loose so I could remove the outer joint.
With just the inner race in place I went to it with a puller but it still wouldn't budge.
Am I missing something? These things designed not to come off?
Going to take it to work tomorrow and use the press at the workshop.
Wandering if it does come off will
I be able to get the new one on?
M
RS 175 Lux
M
RS 175 Lux
