Hi everyone
I have a Mk1 Ph1 Clio with the 1390cc E7J engine. I have a few questions about it in general and I'm looking at tuning it. Apologies if it's in the Archives somewhere, I did have a look first before posting
General
1. When changing the cambelt, how crucial is it to measure the deflection of the new belt? All the belts I've done before either used a tensioner with the tension markings on it, or you did the old school twisting of the belt along its longest span. Could I not do this, or do I have to measure Xmm of deflection when Y Nm of force is applied?
2. Which gearbox would I have fitted as standard? Are there uprated clutches available or clutches off other Renaults that would fit e.g. 1.8 Clio RSi, R5GTT? Would I need an uprated clutch with the mods I'm looking at below?
Tuning
1. I'm looking into the possiblities of improving the TB and cam. Is there anything from the Renault range that could be used to improve things? I read that a TB off a Laguna could be used - which Laguna? The 1.8? Is it a straight fit? What about a cam? A new cam from a specialist would be a bit strong pricewise considering how much the car has cost me so far. Of course this will be with induction and exhaust mods.
2. Is there anyone who could rechip the E7J ECU to make the most of the mods? The only 2 specialists I knew of in my limited experience of Renault tuners are K-Tec (they don't do anything for the E7J as far as I can see) and Hillpower (who seem to be no more?). Fitting the chip myself shouldn't be much of a problem.
How much of an improvement could I be looking at with all this?
3. Would improving the brake pad material improve the braking by much (Bendix 238mm), or would the RSi brakes be a suitable upgrade? Or would I be better off just fitting the fronts from a Clio Valver? Could I use 14" wheels with a Valver setup?
Apologies for being a newbie with a barrel load of questions. And to stave off the inevitable 'stick a Valver in it'/'buy a Valver'...I don't want a Valver
I'm quite fond of the car I have now, including its lump and this would be just for fun
It also goes without saying, I would have suspension mods on the cards too.
Cheers
General
Tuning
Cheers
