Hello, Im looking to install KW coilovers and get the car set up properly. Also Im using spacers for the wheels, was thinking 15mm front and 10mm rear, sounds about right? BTW does anyone know were I can find longer wheel bolts, did a search and found out that Scott @ SG motorsport had them, mailed him but no answer yet.
What do you guys think of K-tec solid top mounts, is this something to go for or are new OEM top mounts better? Going to hopefully do 3 or so trackdays this year, otherwise its inspired road use Im aiming at
Do the solid mounts stress the chassie or wheel bearings or something and do you have to service them regulary? How about the standard items, wich part (partnumber?) is the rubber thing to replace or is it a kit you change? Did a search about this to and found a post by James, but not what to change and wich number to order.
Cheers,
Per
Cheers,
Per
