Slight knock from front end
Ali
Have noticed a bit of a knock coming from the front end...
Car has just had new topmounts, drop links and is all tight. Is there anything else i need to look at? Can handles fine and is running great, just mildly concerned!
Without any experience with the vee's but on past cars I would be looking for worn anti-roll bar bushes, lower ball joints and even play on the damper rods mate.
Double check that the top mounts are properly tightened Ali. They sometimes seem it if the cars is jacked up off the floor but go slack under the cars own weight. If they are then as above really.
I have the occasional knock like this but from the rear :rollseyes:
There's always something with cars isn't there!
