Banjo232232
So after owning my vee just over a month and spending £1600 on a cambelt, top suspension mount and 4 new tyres, my vee is still not a happy car. Last night it developed a sort of misfire and then about ten minutes the engine management light came on. It was about this time that I thought oh great a coil has gone.
So this morning i got up made a trip to eurocarparts and purchased a replacement coil and took the vee to my local garage. Diagnostics were ran on the car and came up with misfire in cylinder 1 and fuel pressure too high.
Local mechanic said yeah looks like a coil, i'll fit this one then.
After replacing the coil i took the car a drive and the problem was still not solved, although the light never came back on.
Anyone got any ideas what else could be wrong? The vee is going back in on wednesday to have more indepth checks done. At this point I really hope something with the cam belt has not gone wrong.
Thanks James
* Edit * the first set of lambda sensors after the first cat were going nuts
Thanks James
