All down to steering geometry, this link adjusts the tracking of the wheel and if you get it wrong the best case scenario will be a set of scrubbed off tyres and worse case will be a trip into the undergrowth due to errant handling at the rear. It seems from your posts that you have some issues with the rear end of your car after your incident, strongly recommend that you get it Optiligned to find out where the discrepancies are to see what is actually damaged and what can be adjusted.
The link you are looking at from the Phase 2 has greater and more precise adjustability than the earlier Phase 1, dont know whether you can adjust the earlier unit correctly with a mish mash of parts and whether the threads will be correct or have the required 'bite'.
Thanks for the response Simon.
As always a lot of useful infos!
I won't go the "mish-mash" route, don't worry.
And yes, i definately struggling with my rear axle since i hit the curb last year!!!
So i decided to replace most of the parts of it. This part seems like the rear suspension arms you manufactured (btw how's the progress? 2 week-deadline for renault is almost over :salut: )....freakin' hard to get from renault!
I just got the feeling that it is easier to get ph1 parts at the moment than ph2 parts!
